Installing brake cable ferrules
I've just bought a set of Shimano brake cables. It's been a while since I installed cables, but I seem to remember that the ferrules are normally a tight fit onto the outer cable, but these are really slack and don't grip the outer cable at all.
I'm wondering how to install them! Do they need to be crimped on (not sure how), or is it okay to leave them slack?
Ming the Merciless
There is no mercy
Photo Winner
Inside my skull
Just push on. Are you sure you’ve used brake cable outer and not just thinner gear cable outer?
deejayen
Thanks for that.
I thought they should push on.
I'll have to double-check when I get home tonight.
I didn't actually check to see if it was brake or gear outer, but it's a Shimano brake cable kit (bought from Wiggle) and it was sealed.
deejayen
I tried the ferrules on an old piece of brake housing I found, and they grip that. It's not a tight fit, but sufficient that they don't fall off.
I've looked at the supplied housing - it says 'Shimano M-System'. The packaging says M-System 5mm.
CanucksTraveller
Hertfordshire
You crimp the ferrule, on your wire cutters you should find a little notch or indentation between the levers, about where the levers meet, pop the ferrule and cable into that indentation and squeeze the levers tight.
deejayen
Thanks for that. I'm wondering if we're talking about the same thing. I'm probably wrong, but I thought the wire cutters were used to crimp the cable endcap onto the inner cable, rather than the ferrules which go over the outer cable. I'll need to check my cutters to see if there's a larger notch for crimping the ferrules...
  • Like
Reactions: C R
CanucksTraveller
Hertfordshire
No you're absolutely right, I'd misunderstood what you meant by ferrule, I was referring to the inner cable ends and I didn't read your posts as well as I should have! My apologies, and as you were!
Ajax Bay
East Devon
The ferrules should be a gentle friction slip fit on the 5mm outer; that's all. Do not 'crimp'.
