Installing a star nut on into a 1 1/8 stearer
Sittingduck
Somewhere flat
Hi
As the title suggests, can anybody give me any easy tips to install the star nut without the need for buying a costly nut setting tool?
Cheers
SD
Christopher
I put the long bolt into the nut and tapped it in with a light hammer, checking many times for drift. It ended up pretty straight and no problems so far with it, I had more problems squaring off the steerer tube after cutting it. My forks have a steel steerer though so quite easy to work with.
Steve Austin
The Marmalade Kid
Mlehworld
You need a bolt and an old socket. screw the bolt through the socket into the star nut. insert starnut and tap socket gently with hammer. if it goes wonky, STOP!
If you are careful and tap it gently and evenly on both sides of the socket or squarely it will go in fine.
I've done it like this for years
jpembroke
Cheltenham
I have a long screwdriver for this job. I push the blade of the screwdriver through the hole in the star nut (it's a narrow blade) right up to the hilt. Then I tap it in with a rubber mallet. Works really well.
bonj2
SFNs are fine but aren't the only way. Can use a hop hed doctor/bung type thing.
none of my bikes have SFNs.
02GF74
you cannot use them on carbon fibre steerer!!
also go slowly beacuse once you have gone too far, it is not possible to push them back up and they dig into the stem - part of the design.
