Inner tube
Following on from some of the questions below, what size inner tube do I need to buy?
On a Trek 7.3 - the tyre size is 700 32c?
I am presuming it is a 700 28c that I need to buy bit thought that I had better check.
Also, is there much difference between the manufacturers?
V
VictorL
And meant to add - any good internet sites to buy one or two?
Tubes usually cover a range of cross sections due to their ability to expand to fit which is why you'll read figures like [ 700c x 23/28 ] or [ 26'' x 1.5/1.9 ] on the box. A 28mm tube will work perfectly well in your 32mm tyre.
Internet? Support your local bike shop, you might need them one day.
Fairy nuff. Probably worth spending a bit extra and buying a quality branded tube from the likes of Conti, Vredestein, Schwalbe, Specialized, Bontrager, Maxxis etc rather than some cheapo crap.
