CopperCyclist
I ask because I have some 25/35 tubes left from when I used to run 28mm tyres. I now run 35mm - now, obviously as its marked up for a maximum of 35mm, the 25/35 tube will fit it... but... is it recommended? Is it actually better to fit at the top end of the inner tube range, or the bottom (I.e. would the 25/35 tube fit a 25mm tyre better, or a 35mm) Or, finally, is it better for your wheel to sit in the middle of the range?
