Furkz
hi i bought some new tyres which at 700c x35mm used to rub 28mm and bought a new inner tube also 28-47 to match now the stem is too small in length for my wheels and i cant even get a pump on it. i had a nut as the bottom of the stem. shall i remove this for more clearance?
i have used a schrader adapter to get a pump on it to fill it with air, shall i keep doing this or will my existing tube with the longer valve fit? that is 28/32mm will that stretch ok to 35mm tyre?
please help an idiot
also quick release rear wheel, took me an hour to get it back on lining the chain up and fiddling it back it, is there a quick way or is it always like this the 1st time?
on a positive note i did replace the tyres and tubes without any tools!
