I replaced the wheelset on my elderly MTB because the hubs were dying and the wheels weren't expensive enough to consider rebuilding; a replacement set costing £60 was an upgrade... Anyroad, I took the chance to move from screw-on (where 7 speed means 14-28 and that's yer lot, barring megarange with that big jump which the mech might not cope with) to cassette, where there's more choice and put an 11-32 on. But will the bugger index? Will it chuff! If I adjust the mech far enough towards the small cogs for the 1-2 change to work, it jumps around between 5 and 6 when the shifter's in the 5 position, and jumps into 7 when it's on 6. If I adjust it so that 5-7 are working, then it won't shift from 1 to 2, and may jump from 2 to 1 with the shifter in position 2
I presume that the spacing on 7 speed cassette is the same as on a 7 speed FW - I can't find owt to the contrary. So what do we reckon? Mech can't cope with the wide range cassette? Bent mech? Sticky cable? I don't think it's the last because the mis-indexing is so consistent. Should I start by replacing cable outer? I've got a length of gear outer handy.
