Impossible to remove grease
XKRJAGUAR
Regular
Westhill
Hi,
I recently bought some special edition red anodised q-rings off a friend, he hadn't ridden them much max 200 miles. They function completely fine but the only problem is the white writing on the q-rings is very filthy as seen in picture, I am told it is grease from the chain dropping off, i have tried everything to remove the grease some methods more extreme, I have tried white spirits, wd-40, muc-off degreaser and even a dremel buffer tool at maximum RPM. Has anyone else encountered a problem like this and if so what did you do do remove the filth?
Thanks,
Calum
huwsparky
Llangrannog
Paint it black!
S-Express
If that lettering is laser etched, then I wouldn't bother, as pretty much nothing you do will make any difference. They look ok anyway, so just jump on and ride. You can't be complaining about looks when you have a red chainring fitted to a silver crank arm, on a black bike.
winjim
Smash the cistern
Baby wipes work for all bike cleaning duties :biggrin:
Unless your bike is covered in baby poo, in which case a reuseable cotton terry wipe moistened with water would be my choice. Disposable baby wipes are pretty rubbish at cleaning actual babies.
XKRJAGUAR
XKRJAGUAR
Regular
Westhill
funnily enough when i bought them i thought the same but they actually fit the bike really well as its a red and black bike, actually quite like the chrome on anodised red when you see the whole bike!
Tim Hall
Crawley
I think they get better with experience. When The Boy (now 23) was a few weeks old, I'd used half a pack of wipes and he was still oxed up in shite. Just then the health visitor arrived and polished him up as good as new with a single baby wipe. (Tenuous cycling link - The Boy has ridden to Brighton with ianrauk).
Mad Doug Biker
Just a damaged guy.
Craggy Island
I'll tell the whole embarrasing story one day as a few things happened to the hub before I set about it with a blow torch. :blush:
It was nice to see it glow yellow/blue/white hot against the evening darkness though.....
I am not sure if the late Vernon would have approved or would have been appalled at my use of pyrotechnics.....
