Just got to work out how to get it past the wife
Does it really make that much difference?
Maybe I'm weak but I can't seem to pump my tyres up full with the pump I got free from the bike shop when I bought my bike.
Maybe I should be purchasing yet another thing?
Yup, you'd have to be a man of steel to get anywhere around 100 psi with a hand pump.
Another +1 for track pumps.
i am really intrigued about tyre pressure now. Forgive the stupid question but all this track pump lark is new to me so i really have no idea..........i presume track pumps are more beneficial to those wanting around the 100 mark, if my tyres are only needing 50 is a track pump still necessary, or more so that its just handy for giving you a pressure reading?
My last pump has become more and more useless, to the point where I have invested in a proper track pump with pressure gauge, what a huge difference it makes getting the pressure up.
Have tried to quantify it below. Tyres are 28mm Armadillos. 50psi was all my old pump was achieving and 100psi is the max rated on my tyres. My test run was freewheeling down a slight hill for about 300 metres followed by a very slight incline. The distance in my table was how far the bike would roll from the bottom of the hill (cut off point was when speed fell below 5mph)
Not much difference in max speed but 11% increase on distance was very interesting.
Off course the big difference is how much easier it all feels.
Does anyone have any proper scientifically done data on tyre widths / pressue etc etc.
Say you reduce the rolling resistance at 20mph by 1w but reduce the riders power output by 10w you have a net reduction in speed. IME this is what happens when you inflate the tyre to the pressure which gives the maximum roll out distance.So we could be talking different optimum pressures for different road surfaces? Could get very complicated.Roll out tests are only half the party though, you also need to know how fatiguing the higher pressure is. 100psi is a higher pressure than I run my 700x23 & 650x23c tyres, while higher pressures result in better roll out results the actual power I put into the rear wheel reduces dramatically on medium to rough tarmac & increases fatigue levels a fair bit resulting in much reduced average speeds.
