If you want REALLY noisy brakes..
Banjo
Fuelled with Jelly Babies
South Wales
While i had the tyres and rim tapes off I cleaned up the wheels and put a drop of wd40 on the spoke nipples. Must have wiped a bit onto the braking surfaces when wiping off the excess,
First time I braked it was deafening My usual ly silent brakes sounded like a lorry with rusty brakes doing an emergency stop,I literally looked behind in fear wondering how many seconds I had left on earth.
Couldnt believe it was my bike doing it.
Scrubbed the rims and brake blocks with soapy water , dried and reassembled, now brakes are better than ever and nice and silent again.
gaz
Cycle Camera TV
South Croydon
Should have used 3 in 1. Much quieter.
Deleted member 1258
My Kool Stop salmons squeal like a stuck pig when temperatures are at freezing or below, at warmer temperatures they are smooth and silent, all very strange. :wacko:
Banjo
Banjo
South Wales
By coincidence i have Kool stop salmons, really rate them highly especially in the wet.
Havent noticed them squealing in the cold though.Thought my nose would fall off this morning :biggrin:
gbb
Peterborough
Reading this just reminded me...
As part of my regular cleaning regime (at work :whistle: ) i do several things that aren't exactly recommendable.
Clean the bike then give a good spray with silicone spray. I used to be aware that braking was of course affected, but usually scrubbed it off with a couple of applications of the brakes pre setting off.
The same with WD40...during the winter i clean then spray the calipers with WD then blast it off with compressed air, trying to avoid getting it on the rims/blocks. but they used to squeal for a while as you say.
But then, ive since fitted Ultegra pads....and it doesnt happen any more.
Were the older, cheaper pads harder ?, more affected by WD / silicone.
But yes, WD on the rims or pads can make your bike howl like a banshee :biggrin:
