Hi everyone,
Not had my track pump very long but I'm having a big problem getting it to actually pump up the tyres... basically I have a presta valve on the bike, I'm using the presta end on the pump, so I unscrew the nut on the tyre a little bit then connect the pump...
...but the dial on the pump doesn't show the tyre pressure at all, it just shows it at 0 even though the tyre isn't completely flat, which obviously seems wrong. Then when I pump it up, I get to about 120psi and it physically will not go any higher - but none of that air has actually gone inside the tyre.
It used to work before, and I'm not sure what I'm doing differently, but any advice would be great as I've now got super soft tyres from all these failed attempts letting air out each time! Please help!
