Washers come in the same size as the bolt there going to be used with,  M4, M5, M6 etc.
You can also get what's sometimes referred to as a 'repair washer' still the same hole size but larger diameter which is usually in mm , M5 x 20mm for example.
I would think a standard M5 washer (if that's what threadsize it is) would do you.
