flat-pack
Riding in to work yesterday I felt the rear wheel start to 'drag' so stopped checked it over and found nothing obvioulsy wrong, couple of miles further on stopped at post box and wheel jammed solid at one point on the rim. Now I need reading glasses for up close work but I thought I could see the tyre had popped from the rim. Upturned the bike and then saw what you see below.
Seems the rim had just worn through, LBS said they had seen it a couple of times, there is a groove on the rim which apparently is a wear indicator, although my groove was still visible. Just glad it happened gradually and at low speed, when the new wheel went in i needed to slack off the brakes quite a bit from their existing position suggesting considerable wear had taken place.
Just a heads up really, I will be looking carefully at my front wheel rim now ! Bike is about 3 years old covered about 7000 miles.
The front wheel over 2000 miles on is still going strong an its wear marker shows no sign of wear. Its like rear tyres most of the rider weight is over the back wheel so they wear out first.
