fatblokish
- In bath
In fact, having inherited an knackered old lawnmower, I once set about cannibalising the orange flex to use as an extension lead. I cut off the old weird shaped plug that slotted into the mower itself and replaced this with a conventional plug. A rather painful electric shock then followed before the realisation dawned that instead of a replacement plug, I should have used a replacement socket.
Anyway, I want to wire up a 240v flashing LED light. The LED bulb itself should be the sort that is often found to indicate that equipment is charging, 3mm diameter? And red.
Can this be bought in Maplins, and if so, what do I need.
BTW, I absolve anyone replying to this thread any liability for my own incompetence.
ta
ta
