I actually managed to true a wheel!
  • Thread starter Deleted member 35268
  • Start date
Shock horror - after 10 years of "serious" cycling, I finally managed to true my back wheel.
It's a Giant PR2 Disc and it had a serious amount of wobble in one area.
I held a piece of cardboard against the frame to slow the wheel at the buckle, then I turned the opposite spoke clockwise (not knowing this was loosening the spoke)
Nothing much happened so I took an unused wheel to check which direction tightens - counter clockwise,
I then located a few spokes near the buckle, opposite side, and gradually made a few turns.
Within a minute the wheel was perfect!
Saluki
World class procrastinator
Well done.
I wouldn’t do this myself as I don’t trust my skills for truing, but applaud those who can do it.
GuyBoden
Warrington
Too tight and the spoke will break, it's sometimes better to loosen the opposite spoke than tighten.
Chris S
Birmingham
Whenever I try to true a wheel the corners come of the nipples (if they haven't already). I've got used to them being 2-3mm out in some places.
With wonky wheel you have to find the compromise between true rim and even spoke tension. The spokes should twang to the same pitch but if the rim was wonky before the build they never do.
It's so easy to true a minor buckle. Only takes a few minutes. All you need is the spoke key and to be able to wind in the brake blocks to act as a guide.
