Billy Wizz
- North Wales
People keep comenting on my disc brakes,the most common is,"oh i have hydraulic disc brakes"mine are cable,Boardman Hybrid,is there a significant difference.?
In terms of power, possibly, but decent cable disc brakes are fine unless you are a front row forward pitching yourself down 20 percenters every day with a fully laden tourer.People keep comenting on my disc brakes,the most common is,"oh i have hydraulic disc brakes"mine are cable,Boardman Hybrid,is there a significant difference.?
What's to faff with on hydraulic brakes? Fit, adjust, check pads, change pads occasionally, and at the same time clean with IPA, possibly ten minutes work.
No I'm not. I said some models, and was referring to the Avids on my Boardman. I also referred to the outdated Hopes that took a lot of faff to set up. I wouldn't recommend either model to anybody. In that post I stated that Servo Wave model Shimano brakes are more or less maintenance free.Cubist you are contradicting much of what you said yourself in this thread a week ago.
In my post above I specifically said "decent hydraulics" and I would never put anything by Avid in that category. .
The Elixirs on my Boardman were great for commuting. I can't remember a week on that bike when I wasn't faffing with the brakes in some way shape or form however. The general consensus in the MTB community is that they are good when they work. Bleeding is supposed to be a nightmare, and doesn't always restore feel to the brakes. For that reason, I would say keep the Avids ( they come as OEM on thousands upon thousands of bikes) until they misbehave. If you can't get them right, fifty quid for a set of Deore would be money well spent.Is that all Avid as I have Elixir 5's and they seem pretty good. Not had to do the bleed procedure yet so there is time for that to change yet. Only thing I can't get on with is the rear is a little snatchy when its on the back wheel.
In my post above I specifically said "decent hydraulics" and I would never put anything by Avid in that category. In twelve months I have replaced the pads in the SLX brakes on my Cotic a few times, but haven't had to bleed them once, nor have I had to centre them since initial setup.
