roubaixtuesday
self serving virtue signaller
I've not changed a set of pads before.
Old ones were Tektro, new ones shimano.
Front ones, no problem.
Rear ones, found it almost impossible to get the cylinders far enough apart to get the gap between the pads wide enough to accept the disc rotor. Eventually, using a tyre lever to prise them, just managed it. Now the brake just ever so slightly drags. It's not the alignment, they're just very slightly rubbing.
I *think* this means the new pads are just a smidge thicker than the old ones, and a small amount of fluid needs bleeding.
But I'm a bit loth to risk ending up with a puddle of fluid and no brakes, so tempted just to let them wear in which will probably take no time.
Is my diagnosis right?
Advice on way forward?
Pics of caliper & lever:
