southcoastden
I took the front wheel off my mountain bike recently to transport it and when I went to put it back, the disc would not slide between the brake pads. I used a small screwdriver to prise the pads apart which enabled the wheel to be inserted to the forks. However, the pads are now rubbing on the disc when the wheel is rotated. I was wondering if the pistons or whatever operates the pads are sticking and if this is easily resolved?
