Until a couple of days ago my bike had cable disc brakes. At the weekend I changed them to hydraulic disc brakes: I kept the existing rotors and fitted some 2nd hand levers and calipers (Shimano BR445). Before fitting them I checked that both pistons in both calipers moved OK, which they did. No sign of oil leaks either, but more on that in a bit...
My problem is that the brakes squeal like mad when I apply them, I mean *really* squeal. It sounds like the Four Horsemen of the Apocolyse running their fingernails down the devil's blackboard, whilst a group of typical One Direction fans clap eyes on Harry Styles. It's enough to make small children cry as I cycle past them whilst braking.
My rotors are resin-only, so I wondered if the pads that came with the hydro brakes are non-resin. With no easy way of telling by inspection alone, I removed the pads that came with the hydro brakes, cleaned the rotor with brake cleaner, and inserted the pads that I used with my cable brakes (a combination of pad and disc which I know was squeal-free). The squeal is much reduced (not gone though), but now the brake lever moves quite a lot before the brakes start biting. The old cable-brake pads have much less meat on them than the ones that came with the hydro brakes, but even so I thought that hydro brakes were self-adjusting such that the pistons stay close to the disc, instead of retracting all the way back into the caliper (which seems to be what's happening).
When I took the hydro pads off, I thought I felt some oil on the back of the pads (i.e. where the piston pushes it against the disc). It had been raining but it felt like oil to the touch.
Any thoughts/ideas about eliminating the squeal completely, the excessive lever travel and other symptoms of oil loss at the caliper to watch out for?
