Jfpklondon
- London
what are the differences and pros and cons to the various types of hydraulic brakes?
Hydraulic or mechanical?
Which ones are you looking at, brand and model, then someone may be able to help. It seems like TRP are good, Tektro less good, Shimano somewhere in the middlewhat are the differences and pros and cons to the various types of hydraulic brakes?
Very very few 'closed' systems nowadays - any that are around are old. Even just standing a bike wit a closed brake system in sun could end up with pads jamming on as fluid expands in heat!There are open & closed systems, most are open but I did have some Giant brakes that were a closed system.
Closed systems do not have an automatic expansion reservoir that the fluid can move into, and out of the main system, when it heats up and expands. An open system has such a reservoir. Almost all hydraulic disc bike brakes are open systems with the expansion reservoir as part of the brake lever (master cylinder) unit. . The problem with closed systems is that long downhill braking causes the fluid to expand, which causes the brakes to start dragging on their own, causing more heat and more drag, until the brakes lock up entirely.
OP did specifically say 'hydraulic'I think the OP means the difference between full hydraulic, mechanically activated (wired) hydraulic disc brakes.
What happens if you don't replace the DOT fluid every 2-3years?.
Good cos it's the same stuff in there since I bought the bike about 6 years ago, sludge or not they still appear to work well!On a bicycle, nothing, so there's no need to do it.
The brakes are under a lot more strain on a car, so periodic fluid replacement is advisable.
But once again, many cars brake perfectly well for years on end with the same fluid.
