Reynard
- Cambridgeshire, UK
Forgive me if this is a daft thing to ask.
As I've discovered, there are freewheels that don't take the standard splined removal tool. Not a problem, other tools and removal methods are available. But what I've in mind to do is to take a good freewheel that doesn't take the standard removal tool off one bike and use it to replace a damaged freewheel that does take the standard tool on another. As far as I can see, that part shouldn't be a problem as the hole for the axle seems to be much of a muchness. Both freewheels have the same number of sprockets and the same ratios, so in theory, it's a straight swap.
What I really want to know is whether the thread that fits the freewheel onto the *hub* is universal or not.
If it is, then I don't mind swinging for the right removal tool (tools don't go to waste, right?) and carry on as planned. If it isn't, then some thinking is required as to where to go with this project.
The damaged freewheel is a 5-speed Shimano SIS, which came off with the standard removal tool.
The freewheel I want to replace it with is a 5-speed that is stamped Falcon . Lifei Co ltd - this also takes a splined removal tool, but it needs one that is a good two to 3 mm narrower than the standard.
Any thoughts?
Any thoughts?
