Hub gearing question
Dec66
A gentlemanly pootler, these days
West Wickham
A mate of mine, who doesn't cycle a great deal, is about to do L2B on his hybrid, which has Shimano Alfine 8-speed hub gearing.
I'm trying to work out what his ratios would correspond to in terms of the teeth on an 8-speed cassette if he had a derailleur setup (upfront is a single with 39 teeth). Would any clever people who understand this stuff be able to calculate rhat, based on the following ratios:
0.527
0.644
0.748
0.851
1.000
1.223
1.419
1.615
Ta :smile:
raleighnut
Dec66
Dec66
West Wickham
Dec66
Dec66
West Wickham
I run Alfine 8 with 170mm cranks and 32mm tyres. Bottom gear is 31 inches and top is 93 inches. Broadly comparable to 50-34 x 9 speed derailleur set up.
Your friend/you can get the exact inches for every gear via Sheldon's gear calculator:
https://www.sheldonbrown.com/gear-calc.html
Edit: Nexus 8 and Alfine 8 are the same internally.
Ok ta, was sure I'd seen different ratios on the Nexus though
Moodyman
Nexus came out in several interations. The final version (Nexus Premium 8) has identical internals to Alfine 8. The only difference being the shifter and hub sealing - better on Alfine.
TheDoctor
The TerrorVortex
Assuming your friend has the 18T sprocket, then that's like having a 9.5 - 29.1T cassette.
Specifically, a 9.5 11.6 15.3 18 22 25.5 29.1T cassette.
Those weird fractional values are why you don't normally try to work this out!
You're probably better off considering the actual gear inches, development or some other measure.
Or even just an overall percentage.
I'd be far more interested to know that if I geared for, say, a 25" first gear, then my top is 77" for that hub. Lower than 25" I may as well walk, and I can spin 77" up to about 30mph (but not for long!)
