Hub gear options
skwerl
London
A colleague is looking for an new bike. He used to have a Nexus-based one but says the spread of ratios isn't wide enough so keen on going with anothe Nexus/Alfine-based nike this time.
Rohloff is too expensive
Any options that could provide a hub gear bike with a wider ratio spread?
I don't think changing the planetary gears on a Shimano 8-speed is a possibility
hubgearfreak
here's 4
http://www.chargebikes.com/products/cbikes/index.html
(models : mixer & tap)
http://tinyurl.com/6jmnce
http://www.swobo.com/catalog/product_info_b.php?cPath=201_204
although my preferred route is to find a cheap cromo frame from ebay, or better still the tip/skip and build my own wheels for it. you'll get equal quality to any of those and unique to you for considerably less.
of course, before everyone started seeing the light and the market responded with the above, it was the only way to get one:thumbsup:
hygienic
Exeter
hubgearfreak said:
here's 4
any advice on frames for a Rohloff? Do you need forward dropouts so that you can take the back wheel off easily, or is this not a problem?
Ratho
You don't need forward facing dropouts to take the wheel off (mine have veritcal). What you do need is a means of keeping the chain from going slack and forward facing dropouts sorts this out (as does an eccentric BB or an idler)
