Hello, I'm building up an early 80s road bike and want to use 80s Gipiemme Sprint or similar hubs (not yet sourced). The frame spacing seems to be 128mm. I have a 5 speed Italian threaded freewheel on it's way to me by post. Other than the threading, what specification do I need to look for in the hub? Will I need to use some sort of spacer, as I read that 5 speeds were originally fitted on frames with a 120mm span on the rear forks?
The front forks have a gap of a bit more than 10cm.
Thanks!
Thanks!
