How to set time on Dogcam Hd Wide
Cordulegaster
Maidenhead
I've lost the manual. Well the bit of paper that tells me what to do. The time is an hour or so out and it will be two hours out when the clocks change.
I remember it's a text file but what do I call the file and what is the date and time format?
If anyone has one or can remember, it would be helpful to know.
Glyn
Pete Hurford
Fordingbridge
A bit late I know - I had the same question and could not find the answer on the web. However I do still have the instructions, so here goes:
You need to create a text file called TIME.TXT in the root folder of the memory card. Its a single line file, the format is:
YYYY MM DD HH MM SS
where (hopefully obviously) the first MM is month and the second MM is minutes.
It gets sucked in when the camera is next turned on. The camera deletes the file so if you reconnect the camera to the computer, the absense of the file indicates success.
Alternatively just look at the timestamp on a movie :smile:
