How to measure B.C.D.?
Cyclopathic
Leicester.
When faced with a naked chain ring what is the best and most accurate way to measure the BCD? On asymetric rings you can't simply measure across from one to another and divide by two and I can't work out a way to quickly locate the very centre of the ring.
I'm looking for something as accurate as possible because some rings from different manufacturers can seem to vary by quite small amounts.
it's usually stamped on it somewhere.
Poacher
Gravitationally challenged member
Nottingham
Very useful link, Biker Joe. One reasonably common size missing from that list: x=50.5 mm, BCD 86 mm. This is for various old Stronglight cranksets, and one I still use on my commuter. Chainrings for this are now scarce!
Do you remember when you were at school learning trigonometry? Well here is a use for it!
If you have digital calipers you can easily measure the distance between the holes, if not use a rule and measure from the edge of the hole to the same edge on the other hole which is easier than trying to guesstimate the centres.
Why is it referred to as a BCD? At work it is always pcd, pitch circle diameter.
Rob3rt
Man or Moose!
Manchester
BCD = Bolt Circle Diameter. PCD is the same thing. Probably just an adaption to make it more intuitive.
