dodgy said:I use my mouth, you need to get a really good seal around the valve and it helps if the valves are of the long variety. Smear some vaseline on your lips for an extra good seal and simply blow, you'll know when you're near 100psi as faeces will squirt out of your arse and pebble dash whatever is behind you.
