How to change a quill stem?
4F
Suffolk.
Bar tape off and feed through the stem. To remove the stem turn from the forks turn the allen key 3 rotations and then give the nut a knock with a wooden mallet. The stem will then easily come away.
Do not keep turning the nut with the allen key until the nut comes out as then you are cream crackered.
Deleted member 23692
yup - remove the tape and feed the bars though the stem (after slackening the bolt first ;)).
youngoldbloke
You may have to prise the stem open a smidgeon - but no more - to get the bars out, but there is usually a way, twisting and turning the bars this way and that.
02GF74
if the bars were fitted, then they can be removed - good tip with the coin to wedge it open:pump: - take is slowly if you do nto want to sctach your bars.
