Deleted member 20519
So here's the story, I brought the bike into my LBS on Friday and I specifically asked them to fit a new gear cable, adjust the gears once said cable was fitted and locate the grinding noise coming from my back wheel.
I call them today and the bike's ready to collect, I ask the guy if the grinding noise has been fixed and he tells me yes, the back wheel needed trued. Sure, not sure how that works but fine.
I head down to the shop, the bike's hanging up on the wall looking lovely next to all the lovely pieces of carbon. The guy comes over to me and takes it down, everything's looking fine. I ask him if the wheel's fixed and he says yep, he trued it and adjusted the brakes - he fitted the new gear cable and adjusted them too. Great! Fifteen quid changing hands and a chat and I'm on my way.
Outside, have a check over the bike to make sure it's all good. The wheel grinding is *not* gone, the gears are *not* adjusted but apart from those two things which is the reason I booked it into the shop in the first place, it's all okay.
Now, I hope you enjoyed my story but I want the gears to be fixed. I'm not too pleased about the rear wheel, I think it's the hub, so I might just take it down to the shop tomorrow and book it in again. The issue with the gears is that when I'm pedalling and stop, the chain goes into ultra-slack mode and loses all of it's tightness and then it takes half of a pedal revolution before the chain tightens up again and I can continue pedalling. I'm fairly sure this can be fixed with a simple derailleur adjustment but there's one problem - I don't know how.
So, you kind people of the Know How section, how do I fix this issue and stop the chain from going slack when I coast?
Thank you!
Thank you!
