roubaixtuesday
self serving virtue signaller
Had an issue with the front brake, OK set up on the stand but after a short distance, would be rubbing one side.
Applying the brake stopped the rubbing, but came back again shortly.
Adjusting the centring screw seemed to make little difference.
On investigation, the main retaining bolt seemed a little loose, and tightening it seemed to solve the problem.
But how tight should it be? Done up hard, the caliper doesn't swivel at all. Too loose seems to result in the issue described above.
So, how tight should the brake bolt be?
