How tight is 6 Nm?
Young Un
Worcestershire
My carbon fibre seat post arrived today and I would like to fit it for tonights TT. However, in the instructions it says to only aplly 6 Nm to do it up, so how much is that?, I have got a torque wrench but it only goes down to 50nm and so isn't useful at all.
Cheers
Steve
ianrauk
Tattooed Beat Messiah
Rides Ti2
Can't you set your torque wrench to the amount you need?
And don't you mean UP to 50nm?
Tynan
e4
tee hhe, use a metre of wrench and hang .6Kg off it
I think, check the metre and the 0.6KG but you get the idea
I do my carbon seat post up as tight as I can with my multitool, it's never occured to me to worry about how tight
cisamcgu
Merseyside-ish
Hmmmmm.... imagine a spanner 30cm long then if you hung two bags of sugar from the end of the spanner when the spanner was horizontal and attached to the bolt, that would be pretty close to 6Nm
Andrew
yello
back and brave
France
6nm is bugger all. Go easy.
Use the smallest spanner you can find (i.e. length, not bolt size!) and DO NOT heave it up tight. You'll have to go by feel but I reckon to aim for just as it bites/starts to stiffen and a just touch more.... but feel is everything here, do not be tempted to over-tighten.
It's a seat post so you'll be able to gauge very easily if it's too loose! Just gently does it until the post feels secure.
Edit: just dawned on me; seat post, it'll be a hex bolt in all likelihood. That's allen key territory. Same theory but you'll not need to be quite so gentle, allen key's flex a little so you'll be able to give that more beef. Surprised Tynan is brave enough to give it full welly but it's obviously ok!
MacB
if it cracks then you've gone too far.
Seriously, size of tool/length will make a difference, what feels like a lot of effort with a tiny allen key will feel like nothing with a longer lever arm.
I keep seeing the NM recommendations but have been loathe to spend ion a torque wrench. Going by feel at present, will probably break something at some point though:blush:
jimboalee
Solihull
It how you use it. :smile:
