If you use the "loctite" brand of threadlock, the packaging is colour coded in strength.
Just avoid the black one, as that is designed for permanent use, and not for disassembly.
Another suggestion I would have is to avoid using threadlock in low torque situations, as often the thread lock can make it stronger than the component itself. Additionally, bolts vibrating loose are often a cause of them not being tight enough in the first place, nuts and bolts tighten by the stretching of the bolt and the clamp tension then under the bolt head. Inadequate tightening will allow movement through vibration due to lack of tension.
It is worth noting that most applications that it is used, are safety critical components that are not designed for removal, if it's a nut and a bolt that isn't captive, you have better, options than a thread locking compoud, such as star washers, spring washers, nylock nuts, stover nuts, etc. Thread lock isn't usually my first choice for keeping bolts together,
