Stick on a Giant said:None! The key to an oiled chain is getting it on the inside of the bits - which you can't really do effectively from the outside, unless you take the chain all to bits, which is why they do it when they put it together. There's been other posts on this, and Sheldon Brown always has something on this.
Quote: This page created April 1, 2007bonj said:http://www.sheldonbrown.com/chainclean.html
You should always do this once a week.
Maz said:Quote: This page created April 1, 2007
Unkraut said:I find WD40 quite good in winter when the ground and air is damp, as this does not accumulate and I cannot imagine much dust and muck sticks to the chain as would be the case with oil..
Chris James said:You've gone and done it now. Mickle'll be along any minute to inform you that it isn't a lubricant (yes, I know it says on the can that it lubricates).
I use TF2 which seems okay, although someone will also tell me that it is rubbish and I should be using something else.
