How long has "new" 52+36 been around?
derrick
I have been using one for the last couple of years. Am sure it has been around longer than that.:wacko:
Poacher
Gravitationally challenged member
Nottingham
I fitted a Stronglight 36/52 to my second-hand Bob Jackson frame soon after I bought it in ~1980. Still using 86mm BCD chainsets on a couple of bikes!
  • Like
Reactions: mjr
Sharky
Kent
Hard to understand what the hype is all about. A two tooth difference on the front is less than one tooth difference at the rear, so the change from 50/34 to 52/36 is minuscule. Can't really see what the advantage is or even the disadvantage. At the top end a 50x11 is more than enough for racing and at the bottom end, most people, on here especially, keep asking how to get a lower gear to cope with the hills.
The only radical change I've seen recently, is the movement to a single chainwheel, with a cassette range giving the same as a compact, but with the simplicity and smoothness of just one lever to worry about.
mjr
mjr
I fail to see where the smoothness is in the chain twist of a 1x10 grinding away! If you want a wide range single shifter setup, there's always hub gears.
Thanks all for some pointers back. Has anyone got an known early dated 52+36?
Fab Foodie
Kirton, Devon.
Continental types have been using a combo of big ring and a granny ring for years, since the first days of double chainsets, so it's nothing new. Furthermore tourists using TA chainsets used any combo they pleased. Like much in modern cycling there is new hype for old ideas. It's called marketing.
Sharky
Kent
Chain twist or cross-chaining issues are not quite as sometimes perceived. With big/big or small/small ratios, the problem can be having too much chain or too little chain and the RD unable to cope or rubbing on the FD. If optimized for a single chain wheel, say 40T, then this disappears. And the newer RD's coming out are much more effective in taking up chain slack. I've been running a 1x9 combo with a 40T chain ring for over a year without problems.
