Thanks for thatIt will look like this, the axle and bearings.
I made up a refitting tool with a long bolt washers and a nut..
You use the axle to remove the first bearing, tap from hub side after removal.
Use axle to tap out other.
Use the bolt washer press to install.
Or whatever you can knock up.
You must only apply force to the outer race.. Installation, use old bearing for this if you dont have a big washer etc
Hth View attachment 453041 View attachment 453042 View attachment 453043
I had heard about the 'whack with hammer' method, but didn't want to go at it without confirmation!
New bearings are necessary, so I need them out to measure what size to order.
Thanks
Edit: Which side is best to start from, or doesn't it matter?
Thanks. I've used SKF in the past and they've been good as well.When you get the bearings out you should be able to read the product code or size either on the metal itself or the plastic seal ring. Kintetic Bearings is a good site to see the sizes and buy online - various qualities of the same size etc.
Rob
I worked with bearings on a daily basis, all types and sizes. We would use SKF / NSK / FAG bearings, not worth using cheap bearings and as we were routinely getting 80%+ discount the difference in cost was not worth the potential hassle of premature failure.Thanks. I've used SKF in the past and they've been good as well.
cut cut cut cut..... often appears too little, but the most common cause of premature bearing failure is over greasing.
The way it was explained to me is that if there is too much grease the individual balls can't roll inside their cages as they are meant to and start to bind up. The bearing still rotate as the cage with the individual balls slides round between the inner and outer races, causing heat, the grease gradually gets less " greasy " causing more heat etc.
When I was working a colleague and I were called out to a breakdown at a local factory ( Ryvita )
There were several very old cast iron frame motors in one particular location. The one that they were concerned about was quite big, about from the floor to my knee in height and we could hear that the drive end bearing was knocking quite loudly.
After we'd isolated the supply and removed the drive belts and pulleys we took off the drive end endshield.
Imagine a big dish at least a couple of feet in diameter, that's what we had, but it was filled to the brim with grease, we were scooping out handfuls of the stuff.
The maintenance man would go around the plant every Friday and grease everything with a grease nipple. Over the course of years the grease built up eventually fill up the end shield.
As I was writing this I realised that my experience with bearings was in an Industrial setting, the bearings typically rotating at several thousand RPM and usually at high temperatures. I can't imagine that bike bearings would experience anything like this, and contamination through the ingress of water / crud would pose a much greater problem.
