Milo
- Melksham, Wilts
Smash out and install a new star fangled nut without going horribly wrong?
miloat said:No you are wrong with b bonj it was indeed A.
It seems to still be tight enough though might not bother.
02GF74 said:the cap bolted to the SF nut is only keeping the headset bearings at the correct setting so if it goes loos or falls off, you will get some knocking rom the headset.
the two nuts on the side of stem keep the bars on the bike point in the right direction and stop the forks from dropping off!! these should be tight.
