night cycler
- Rotherham (near town)
Can anyone tell me how to establish what gearing the cassette has?
I have a quote from a cycle shop for a new (shimano) chain & cassette if required due to slipping in the top 3 gears. Cassette £55, chain £35 and the labour to fit the pair £25Don't know what your reason might be. Order a new cassette?
Maybe you want to work out the gear inches, in which case there are online calculators.
That sounds like the perfect cassette. Always having one more gear to drop into is the ideal.I don't really use the lowest gear, and only use the next to lowest occasionally on some hills
Yeah, but don't you know most on are pro racersAgreed, I always find it funny when people worry about having an 11 or 12 tooth cog. Unless you're a pro racer then when you run out of gears then you're generally going downhill, so freewheel and have a rest
