How do I remove the freehub body on this wheel?
  • Thread starter Deleted member 121159
  • Start date
Hi, this is a Cube branded wheel made by Alexrims. Does anyone know how to remove the freehub and which tools I will need?
Cheers.
Update: It takes 12mm thru axle.
635514
635515
cyberknight
freehubs are normally a hefty allen key , could be 10, 11 or even 12 mm as there are so many standards
View: https://www.youtube.com/watch?v=icOGagzOJ14
You are possibly going to have to google. My through axel hub - pop off the non-drive side end cap, hex key in non-drive side, then undo drive side end cap, and freehub just slides off. You've got flat's on the axel so I'd suggest they are similar.
Found someone else trying to take apart the same wheel. Apparently it was 14mm allen key they needed. I suspect it'll be as fossyant said, pop off end cap on non drive side, allen key in, and unscrew drive side. Now off to Amazon for the allen key...
