How do i get a rack to fit ??
Landsurfer
New bike, first with discs and the altered frames they have.
I have number of good quality racks, there are mounting holes on the “lugs” .. but .. the frame directly above the mounting points comes out by approx 12 mm stopping the rack vertical arms from being fitted ... am i missing something ? Is there a fitting that needs to be attached to the frame to allow the fitting of a rack ?
605301
stoatsngroats
South East
Would this fit, as it looks to have an adaptation at the bottom of the leg?
Wiggle
You may need longer nuts and washers to space the legs out (if you can) of your existing racks. The other option is a disc specific rack.
Baldy
ALVA
You could try some longer bolts with a 12mm spacer (short piece of pipe), could be cheaper that a new rack.
ColinJ
Puzzle game procrastinator!
Wiggle
I have one of those on my CX bike to make sure that the left side of the rack mount clears the rear disk.
