Spooky - I also have a Defy2 (2010) and have just ordered some 68mm Ultegra BB cups from ChainReaction for £15 - cheaper than the lower model 105 version.
It is pretty hard to get to the bearings inside the Shimano Hollowtech BB cups due to quite an akward to get at (and delicate) rubber o-ring seal, so picking out the seal to clean and regrease the bearings is...well, maybe you can manage it with a pin or the pointy end of a stanley knife, but for the sake of 15 quid I won't bother trying.
Hopefully it will banish a new click the bike has developed after 5K miles of all year round riding.
Thanks for that, for the sake of £15 it makes sense....Thanks for the `68mm Ultegra` mention, I wouldn`t have known what to look for...
I`ve not taken the BB off before, have done approx 2500 miles. Getting the feel of it being "harsh". Maybe a clean will help. But as you say £15, cheap enough.
Cheers
I've tried the Hope BB (see here)
Personally it didn't provide a performance upgrade so I eBayed it - it may last a bit longer but at the price I'd stick with Shimano.
Cheers
Ta for the tip. I guess I will see when I take the existing one off...I may not have to use the new one just yet, but nice to have a replacement to hand just in case.Sounds like the BB has worked a bit loose - I wrap some ptfe tape onto the threads to hold them firm.
I swapped my HtII BB earlier this year. There was a little bit of slop in the old one and the replacement cost me under £13 from CRC.
With the right tools it's a five minute job.
Hi,
Another thought, has anyone just replaced the bearings with better quality ones. Have googled, various ways of doing so...just want to be sure if I were to go same way, I replaced them with correct bearings which were of better quality. Would ceramic be taking it a bit far?
Cheers
Kinda answered this on your other post Koro, but to nail it down in detail.
I did my FSA BB. I have access to SKF bearings and you wont beat them in quality without spending an awful lot more.
If you take a standard SKF bearing (-2RS, two seals) and spin it in your hand, you can feel the drag/resistance. Thats no problem of course, they're designed to run at thousands of RPM in motors etc. Its no real problem on a bike.
If you take a low friction sealed SKF bearing (which is -2RSL, although i think that suffix is old now, they keep changing them)...it spins so much more freely, you can really feel it.
The trouble is, for the average guy to get access to SKFs low friction bearings, you're not going to get them off ebay etc, you'd have to go to a bearing distributor...and they're not cheap cheap, if you know what i mean.
