Hollowtech BB tightness
roubaixtuesday
self serving virtue signaller
Photo Winner
Bought a new BB as the old one had lots of play in it. But, on investigating, just tightening the plastic nut that brings the cranks together solved it (after having loosened off the crank). Presumably it had just loosened off a bit in use - probably done about 5000 miles.
So far so good.
The question I have is how tight should it be? I found that barely finger tight resulted in slight resistance to rotation, and I wonder if the thing will just back out.
Advice please - how tight should the plastic retaining recessed nut be, and would resistance to turning the cranks be expected at barely finger tight?
ianrauk
Tattooed Beat Messiah
Rides Ti2
I tighten as much as I can by hand then back off a tiny.
That works for me.
figbat
Slippery scientist
The plastic tool I have has a torque value on it - from memory it’s ~2 N.m but this is useless since there’s no way of getting a torque wrench on it.
  • Like
Reactions: C R
R
roubaixtuesday
Photo Winner
According to Shimano it should be 35-50Nm.
https://si.shimano.com/pdfs/dm/DM-RAFC001-03-ENG.pdf
or do you not mean the BB halves?
Thanks for the reference, appreciated.
That torque is for the actual BB itself.
I'm referring to what I now know, thanks to your doc, is called the "cap".
The torque specified is 0.7-1.5 Nm (it's a finger tightened plastic tool), page 17.
But like I say, in reality it's more "how do I know if this is right" - a little bit too much results in sight resistance to turning the pedals, and not enough leaves play in the BB. And just right seems suspiciously lose to me at least.
