theloafer
- newton aycliffe
for sale as about due to upgrading would prefer to sell as a pair owning to the need for space regards new bikes arriving soon £3,400 ono just been serviced all updated and all diagnostics paperwork available .... also poss deliver for cost of fuel within reason
his .. Sduro 7.0 returned to stock spec
frames sizes 7.0 is small and 5.0 is xsmall but have found there run on the lager side I am 5-6 leg 30in and find it just a touch big the g/friends is 5-3... which I found fitted me better
Frame
aluminium 6061, HD Interface, quick-release 5 x 135mm, disc brake Post Mount
- Frame
aluminium 6061, HD Interface, quick-release 5 x 135mm, disc brake Post Mount - Drive unit
Bosch Performance CX, 250W, 75Nm, 25km/h - Display
Bosch Intuvia - Battery
Bosch PowerPack, 500 Wh - Charger
Bosch quick charger 4A - Fork
SR Suntour NCX-EB-DLO Lockout, steel spring, Travel: 63mm, steel steerer tube 1 1/8", quick release - Shifting system
Shimano Deore XT M8000 Shadow Plus, 11 speed - Gear lever
Shimano Deore XT M8000, rapidfire - Rear sprocket
Shimano SLX M7000, 11-46 teeth - Chain
Shimano HG601 - Chain ring
Miche, 16, steel - Brake lever
Magura MT4 - Front brake
Magura MT4, 180mm, 2-piston disc brake - Rear brake
Magura MT4, 160mm, 2-piston disc brake - Tyres
Michelin Protek Cross, 42-622, 28" x 1.6" - Rims
Rodi Black Rock 21, with eylets, hollow rim, aluminium - Front wheel hub
Haibike Components TheHub ++ - Rear wheel hub
Haibike Components TheHub ++ - Spokes
Sapim Leader, black - Handlebar
Haibike Components TheBar ++ - Grips
XLC Comfort bo3 with wrist rest - Stem
Haibike Components TheStem ++, A-head, Bar bore: 31.8mm, 12˚ - Head set
A-Head Alloy 1 1/8", Cartridge - Saddle
Selle Royal Viento - Seat post
Haibike Components The seat post ++, patent, 31.6mm, aluminium - Pedals
VP E461 mit Reflektor, aluminium - Head light
Herrmans H-Black Pro E, 100 lux - Taillight
AXA Blueline - Dynamo
via system battery - Carrier
system carrier, XLC Carrymore, max. 25kg - Mudguard
SKS, chromoplastics - Kick stand
Ursus Mooi, adjustable - Weight
23.6kg - Total perm. weight
130kg
- Garmin and saddle not included
- rear trunk bag with adapter plate
- removes and installs in seconds
- will be left on
Frame
- Drive unit
SR Suntour NEX E25-LO Lockout, steel spring, Travel: 63mm, steel steerer tube 1 1/8", quick release - Shifting system
Shimano Alivio M4000, 9 speed - Gear lever
Shimano Alivio M4000, rapidfire - Rear sprocket
SunRace CSM980, 11-40 teeth - Chain
KMC X9 - Chain ring
Shimano M315 - Front brake
Shimano M315, 180mm, 2-piston disc brake - Rear brake
Shimano M315, 160mm, 2-piston disc brake - Tyres
Haibike Components TheHub + - Rear wheel hub
Haibike Components TheHub + - Spokes
Haibike Components TheStem +, A-head, Bar bore: 31.8mm, 7˚ - Head set
A-Head Tapered, ball bearing - Saddle
AXA Blueline, 30 lux - Taillight
24.2kg - Total perm. weight
130kg - Wheel size
28"
