Hills operating in the correct downward direction
marinyork
Resting in suspended Animation
Logopolis
1080p chuffing heck. Very good. I went to Ashbourne last month for a few days.
CopperBrompton
CopperBrompton
Bicycle: a means of transport between cake-stops
London
We stayed in a tiny little Hamlet called Wheston. One row of cottages. One farm. And, er, that's it.
marinyork
Logopolis
Yes, I know it, although I don't go to that bit of the park that often, I don't normally go past Calver. There is slightly more to it than that, but not much :rofl:.
Crankarm
Nr Cambridge
Ben Lovejoy said:
Took the trike up to Derbyshire for a family weekend, and managed to drag a couple of them out cycling. Whilst I'm not known for my fondness for hills, I do have to admit there's something to be said for them when operating in the correct downward direction.
View: http://www.youtube.com/watch?v=8cl2nlb7vK0
:o).
You should cycle in the Fens where a head wind is the equivalent of an HC climb :rofl:.
Your POV seems to record excessively dark footage? I know you stated it was bright sunlight and shady conditions but surely the metering system is sufficiently sophisticated to deal with bright skies and shadows?
Atlernatively I noticed you could perhaps angle it very slightly down so it isn't capturing so much sky in an image causing the lens to shut down making the fore and middle ground and shadows totally black?
marinyork
Logopolis
Crankarm said:
:o).
Was it so on Friday/Saturday? It was shocking along the Humber Bridge, northerly winds.
CopperBrompton
CopperBrompton
London
I've spent a bit of time there, so yes, I'm familiar with those!
It copes better than any camera I've seen when cycling towards the sun, and copes with light to shadow well too. I am viewing on a calibrated screen - from your description of what you're seeing, it sounds like your screen is set rather dark.
Heh, the mounting is on a baseball cap, so angle is rather variable. :-)
