Time Waster
You guys who can get away without prescription glasses or have a low prescription are very lucky. I've got a high prescription and it is next to impossible to get preesription sunglasses that offer decent coverage. Mostly I have to get normal glasses with tinted lenses and light flooding in the side for low protection.
Anyway, my new opticians in a nearby village has found a make that would work with my high prescription. It has a frame with a plastic shield that allows a flat, high prescrition lens fit. The frame is kind of wrap around but the lens will fit in them flat. Anyway, being a bit vain I think they look a bit like safety goggles. What do you guys think about the following options. Bear in mind most of the main sports sunglass brands only cope with up to + or - 6 prescription. My rx is a worse than that so the distortion in say a bolle frame would create effectively tunnel vision.
Cruiser
Circuit Flex XL
Element
Lowrider
Do these look a bit too goggle like for on the bike and off the bike / hiking use/ travel use? I did see a pair of bolle RX sunglasses with a similar look just doesn't accept an RX higher or lower than a 6 in +/-. Thing is I need sunglasses to reduce light in summer at times, photosensitive at times. just not sure I can get away with these. Is this vanity, do you think any of these look ok or other? Looking for opinions or alternatives if anyone knows of one.
Cruiser
Circuit Flex XL
Element
Lowrider
