Hi Shaun,
Thanks - I thought about clubs and might do that eventually but I was hoping to find someone to go out with during the week rather than weekends initially. I also thought I might struggle with cycling distance with other members. At that moment I've only managed 20 miles max.
Sarah
I'm in the Avenues area.If you don't fancy a club is there anybody at work / friend that rides a bike that you get on with about the same stage.. if you hook up with someone who is a lot better then it can be s bit disheartening. Hence the suggestion of a club with beginners.
Whereabouts in Hull are you? Bitd I worked for Cliff Pratt Cycles.
Shaun
Ok, thanks for the advice.Hi, there's quite a few from Hull on here. I'm not far away there's a few local clubs, which may be the best way to increase your distance & meet other local cyclists
Thanks SteveI am from Hull. Now living in Denmark.
Sarah, there is a bike club that runs from Cliff Pratts on Spring Bank I believe. Drop in and ask them. They will be happy to advise you.
Hi, I'm new to cycling and looking for a cycling buddy near Hull to go out with and hopefully increase the distance I can cycle.
