Hoo Wheeler
Regular
- Kent
Never tried them, I guess I am too old to take on new technology.
Welcome to the forum and if your location is where I think it is, you might bump into me on a tuesday night in the summer, when the TT's resume down in Grain.
67, 68 in FebHow old are you? 62 here.
67, 68 in Feb
What sealant do you use?As far as repair kit is concerned- I carry 3 CO2 bulbs, tyre levers and a spare tube, plus some tyre worms and superglue. The only items I've had to use are the CO2 bulbs. Some people say you don't need to carry the spare tube but I feel safer with this.
Apparently, latex-based sealants like Stans solidify if you use CO2
That just about corresponds with my experience. In the case of a type 2 puncture, I have found that occasionally the plug formed by the sealant will get worn away after a few rides resulting in another puncture. In each case I've been able to carry on riding without stopping, but when at home I've put a patch on the inside of the tyreWith tubeless, there are 4 types of punctures
1) Those that seal themselves with no effect other than a slight loss of pressure, which you may never notice (thorns, small fragments of glass)
2) Slightly larger ones that you need to encourage to seal by spinning the wheel around to slosh sealant over the hole, Pump required, probably.
3) Those that will seal with the assistance of a worm (rubber coated bit of string, effectively) bunged in the hole. Pump required.
4) Those that are too big to seal at all. You need to remove the valve and put a regular inner tube in, and pump up. This will be more difficult than it is with a regular non-tubeless tyre & rim, and you may need pliers to get the tubeless valve out.
The above is from a road bike perspective
With Slime inner tubes, you should get the largest size that will fit, so the tube isn't stretched too much (which makes getting a successful seal more difficult)
