Help with mudguard sizing
MiK1138
Glasgow
Wide
45mm (you have 38mm tyres) :smile: does your frame have the clearance to take them?
Personally, I'd get Halfords or LBS to fit. At Halfords, you'll pay £8 for fitting. If you're not mechanically competent and very patient, mudguards can be a nightmare to fit.
Also if they don't fit , you should get your money back :smile:
Ajax Bay
East Devon
:welcome: to Cycle Chat
I want to buy these mudguards for it, can you tell me which size i need?
45mm wide ones.
http://www.sheldonbrown.com/tire-sizing.html
ETRTO ISO 5775
I enjoy fitting SKS mudguards. A pretty fiddly job
I agree - give yourself plenty of time. With regard to cutting the stays, read the instructions, measure twice, mark once and because you need fairly hefty bolt croppers, I used a hacksaw. Either way, use a bit of emery paper to smooth the cut stay ends off.
U
User6179
The SKS longboards are decent , very similar to the bluemels but longer and cheaper, 45mm wide ones for £20 delivered
http://www.chainreactioncycles.com/..._dc|pcrid|161855212247|pkw||pmt||prd|261453UK
acook59
acook59
Ok thanks guys, i got the wide ones, just dunno what most of those other numbers mean!
Heltor Chasca
Out-riding the Black Dog
From Schwalbe:
What do the various size specifcations on bicycle tires mean?
Nowadays, bicycle tire sizes are all marked according to ETRTO (European Tire and Rim Technical Organization) standard. However, older English and French tire size dimensions are still used as well.
The ETRTO size speci cation 37-622 indicates the width of 37 mm and the tire inner diameter of 622 mm. This dimension is clear and allows a precise classi cation of the rim size.
The inch marking (e.g. 28 x 1.40) states the approximate outer diameter
(28 inches) and the tire width (1.40 inches). Another inch marking is 28 x 1 5⁄8 x 1 3⁄8 (approximate outer diameter x tire height x tire width); it is also common.
Inch sizes are not precise and lack accuracy. For example, diameters 559 mm (MTB), 571 mm (Triathlon) and 590 mm (Touring) are all classi ed as 26 inch. Tires with diameters 622 mm and 635 mm are both classi ed as 28 inch. Oddly enough, tires with an inner diameter of 630 mm are classi ed as 27 inch.
These classi cations originate from the time of tire brakes. In those days, the exact outer diameter of the tire was de ned by the brake. Depending on tire width, various standards for the inner diameter applied.
Inch dimensions are widely used in both MTB sport and English language countries. Therefore, we will continue to use these speci cations for all tires. But only in decimal form, e.g. 26 x 2.25. Experience tells us that nowadays very few users are familiar with the classical fractional inch dimensions, such as
28 x 1 5⁄8 x 1 3⁄8.
When the 29 inch MTB tire size was introduced a few years ago, it had the same inner diameter of 622 mm, known as 28 inch in Europe.
The latest tire size is 27.5 inches. This tire size is favored for MTBs which are too small for the very big 29 inch wheels, in order to bene t from the advantages of bigger diameters. This is the case, for example, with bicycles having a very long suspension travel or very small frame sizes. 27.5 inch tires have an inner diameter of 584 mm and are identical with the old French size marking 650B.
French size markings (e.g. 700 x 35C) give the approximate tire outer diameter (700 mm) and width (35 mm). The letter at the end indicates the inner diameter of the tire. In this case, C stands for 622 mm. French size markings are not used for all tire sizes, so, for example, it is not used for MTB sizes.
Ajax Bay
East Devon
If you take/took the trouble to read the links in my post #5 above (which I took the trouble to link to, for you), then you'll 'no' more.
