Stu1961
- Chesterfield, Derbyshire
OK...........I have just fitted a new rear wheel, Shimano Acera 8 sp Cassette, Shimano Alivio Crankset, Shimano BB and New Chain....problems are....
1 Chain seems far too long.
2 Crankset and Cassette seem way out of line and the Derailleurs are now way out.
I am summising that I may have got the wrong BB, as the one I took out was not a sealed cartridge type but, just had bearings at either end of a shaft.
I measured the total length and it came up at 128mm long.
The crankset I changed to is 22/32/42.......the old one was 28/38/48
These are the items I used..........
Bottom Bracket
Crankset
Cassette
Rear Wheel
Chain
......any help in solving my problem would be greatly appreciated.
Cheers
Stu
Bottom Bracket
Crankset
Cassette
Rear Wheel
Chain
Cheers
Stu
basically the bb needs to match the chain set.As for chain length, I always understood it as follows: wrap the chain around the largest chain ring on the front and the largest cog on the back, but not through the derailliuer, pull the two ends together and add two links and that is the correct size, cut to size and fit it through the mech and should be tensioned ok, just avoid running on the large large combination or will pull the chain too tight. There may be other methods better at getting the correct size, but that does seem to be a popular method.Don't forget to reset the mechs high and low points to get the limits right to stop the chain coming off and check the tension on the gear cables is correct.Spend some time reading the sheldon brown articles and you won't go far wrong, let us know how you get on.
