Gage
- Tampa, Florida, United States
I need some help in deciding what kind of bike I should get. I Am a fairly experienced mountain biker about 5'9 with good technical skills. I have a pretty good knowledge about bikes and have a good idea of what I want. I just need some help deciding on some things.I will be riding competitively.
I ride trails that are technical, tight turns, steep drops, a lot of rocks and roots. Parts of the trails are fast, other parts are slow and technical, rarely a mix of both. I love to just shred whenever possible.
Suspension: I already know I want full suspension.
Frame: I'm pretty sure I want to go carbon. I'm just concerned about cracking the frame. Is this something that should even cross my mind? How much more likely is it to happen with carbon then it is with aluminum?
Wheel size: This is The hardest part for me. I'm not tall and I'm not short so I could really ride any size. I'd Like to go 650b because it is a nice compromise for the type of riding I do. The problem is I'm not willing to spend a fortune for one and cant seem to find a good deal. So most likely I will have to go 26 or 29. The fun part on me wants a 26er so I can continue to shred like I do since I have already gained the technical skills to ride with one, but the competitive side of me says ill be faster on a 29er in races. I also enjoy the 26er because I can brake better and accelerate out of it. I'm in good shape so working a little harder to control the bike isn't a problem. I haven't spent as much time on a 29er as I would like and I may end up renting one to test. I just cant figure out which one I will be faster for me.
Tires: should I go tubless? I don't mind changing tubes when they get flat. The only reason I even consider it is because my worst fear is getting a flat in a race. Also how big is the weight advantage?
I've done a lot of research on this stuff. Just need another persons input. All help is appreciated. Thanks.
As for carbon versus ally, its really about quality. I have the percetion that carbon can be brittle, where as ally will fatigue, and rubbish carbon is a lot worse than cheap ally. I dont know if ANYTHING in this post will help you decide, but think on this. Would you ask a bunch of petrolheads which car they would recommend. The bottom line is, that its up to you !
