help needed - barnsley-london route
ijazn1
hi people my first post, im new to cycling and am setting up a event for charity. we are cycling from Barnsley to london and i need to safe and legal route, is there naywhere on the internt where i can plan one or does anybody have any suggestions, i tried AAroute planner and avoided motorways but it still taes me along the A1 (m) which cyclists are not allowed on and a few other A roads which are legel.
any help will be greatly appreciated
ijaz
Arch
Married to Night Train
Salford, UK
Whenever I do a long tour (well, that's twice, so far), I do it on paper. Get a large scale road atlas, to give you an overview, a list of places to act at reference points (I'm guessing you'll need at least one overnight stop too?). Then look at the appropriate smaller scale maps to find the backroads between those points. You could buy all the OS landranger maps, but that'll get expensive. With a bit of patience I reckon you could do it on Streetmap.co.uk, or the OS Getamap site, shifting between map scales to get your bearings. If you already have some bits that are ok, you could just look at the bits that bother you, for alternatives.
A really good organiser would then drive the route to check it out (esp things like nasty junctions) - sometimes you can't get it all from a map. If the route follows cyclepaths, of course, you can't drive it, but you could take a bike by car and then explore the off road bits - if you're going to be on road bikes, for example, a really crappy surface might be an issue. Also, if you drive the route, you might find info that's useful but not on a map (like a pavement bike path along a section of main road that might avoid a long detour).
Using maps might also allow you to cut out the odd hill, if you can read contours.
Rammy
google maps allows you to change from car directions to walking directions
this obviously will take you through pedestrian centers etc but google maps allows you to manipulate the route by dragging it about on screen, it also then works out the milage for you.
however, looking last night for a route it told me to go against traffic on the coventry ring road, anyone who knows coventry will tell you going with traffic on the ring road is a bad plan!
I
ijazn1
Thanks
thankyou both for the replys, im goin to have a look on google and streetmap see if my patience is any good lol if not i'll have to do it the old fashioned way with a map!
Thanyou again
ijaz
vernon
Harder than Ronnie Pickering
Meanwood, Leeds
Thanyou again
ijaz
WWW.viamichelin.co.uk
has a bike option. Its routes are quite direct but as far as possible use alternatives to major roads.
