Help...my Cateye computer is malfunctioning
Bigtallfatbloke
I have tried to download the instruction manual but I just get a load of goobleygook coding in a word doc (something is probably wrong my end).
I have a Cateye velo 5 bottom of the range computer. Everything on it is fine except the distance function which is not working when I spin the wheel. The magnet is in place and all connections seem ok (although it behaves as if there is a loose connection i.e it works intermitantly for a few seconds then goes off again).
It has not got wet and I can timagine it's a battery fault as all the other funtions are ok and the display looks normal.:sad::wacko::eek::wacko:
I tried a gentle tap....should I beat it harder?xx(:smile:
stevenb
South Beds.
Did you say that your son had fiddled with the settings BTFB? IIRC you can do a reset by holding in all the buttons....try that..xx(
Bigtallfatbloke
Bigtallfatbloke
...no he had a watch that was on german time...would a reset loose my odometer level? I am proud of my 2766.1 km on it...which of course doesnt include todays efforts:biggrin:
Number14
Fareham
BTFB - If you're getting gobbledegook in a word document it may because the instruction manual is a pdf file.
You need Adobe Reader to view it. Try www.adobe.com to download the free reader.
